The white area for the clothes below is the Undershirt. You can use it to make inner clothing as the second layer.
Chuck_Upper_Overcoat (Upper Body):
You can make a clothing set with shirt on the outside and undershirt/necklace/decoration on the inside.
  1. Apply the Chuck_Upper_Overcoat
  2. Refer to ''How to use Template Images to model clothing?'' to launch the Template Map.
  3. Refer to Template map outline, and start to design the clothing.
Double click on Map Channels to import the edited jpg file back to Character.
Final Diffuse Map:
Final Opacity Map:
