How to combine the skirt segments? |
A. |
Choose the segment that you want and set up axis. |
B. |
Decide the quantity of segment. Copy and then rotate them. |
C. |
Group the segments and make them become a single Prop. |
For more details, please follow the step-by-step instructions below. |
A.Choose the segment that you want and set up axis. |
A-1 |
Apply any segment. |
A-2 |
Choose any segment from the Scene Manager. Make sure that Preference/Display Information/World Axis and
Preference/Object Manipulation/Transform Gizmo are checked. |
Move the segment to the appropriate position and execute Pivot/Scene Root. |
B.Decide the quantity of segment. Copy and then rotate them. |
B-1 |
Calculate the required angle for each segment based on the quantity of the segment (Ex. 12 segments, 360 / 12 = 30). |
B-2 |
Make sure that Preference/Grid Options/Angle Snap is checked, and fill in the appropriate angle (Ex.30 degrees). |
Hold down the Ctrl key, and then rotate the segment. Upon the release of the Mouse key, the segment will be duplicated. Keep doing this until the skirt is complete. |
C.Group the segments and make them become a single prop. |
C-1 |
Apply Dummy.iProp. |
C-2 |
Choose all the segments from the Scene Manager. |
Right click to execute Attach and click on the Dummy to attach all the segments to the Dummy. |
C-4 |
You can operate on the Dummy to move, scale, rotate, and save the whole skirt.
(This Pack also provides skirt templates of composed segments). |
