Votes
0
Product:
Character Creator 4
Version:
4.0
Status:
Released in 4.1
Issue 8441
zbrush goz doesnt let me install the goz to cc4
i get this error window when i try it
i also tried with administrator, and still doesnt work
OS: Windows 10
  •  10
  •  3489
Submitted byahingel May 12, 2022
1 2
COMMENTS (10)
arnoldbanner Aug 31, 2022
After 2 days of ripping my hair out, I finally got it to work. Here's what I did.
1. Copy all the GoZ files from:
C:\Program Files\Reallusion\Character Creator 4\Resource\ICGoZBrush\CharacterCreator
2. Paste them in:
C:\Users\Public\Pixologic\GoZApps\CharacterCreator
3. Open "GoZ_Config.txt"
(That should be in the "C:\Users\Public\Pixologic\GoZApps\CharacterCreator" folder by now)
4. Edit the first line (PATH = "***) to where your CC4 is installed.
In my case: PATH = "C:\Program Files\Reallusion\Character Creator 4\Bin64\CharacterCreator.exe"
5. Open Zbrush, and here's the most important part: DO NOT REINSTALL GoZ!!!
6. DO NOT REINSTALL GoZ!
7. DO NOT REINSTALL GoZ!!
8. GoZ whatever subtool you're trying to send, and CC4 should open this time.
Hope that helps everyone.
Cheers!
ahingel Aug 5, 2022
i found the solution and it worked for me
Copy all files from here:
paste to here:
and then go to zbrush preferences goz
file path to cc4 but not specify the path again. check the 2nd option
and it will work
raymtx Aug 5, 2022
Anybody found a solution because nothing suggested in this thread has worked yet.
songelars Jul 3, 2022
Thank you for contacting Reallusion.
Zbrush needs to be installed an run as administrator. If CC3 Pipeline will still not recognize it, you can try this manual instalation of the components.
Force reinstall GoZ from Program Files\Pixologic\ZBrush2020 (or whatever version you want to use)\Troubleshoot Help.
Manually copy over all the GoZ files from Users\Public\Pixologic\GoZApps\CharacterCreator to the character creator folder in Program Files\Reallusion\Character Creator 3\Resource\ICGoZBrush\CharacterCreator (Replace all the existing files with admin permissions. I recommend backing the files up first though, just to be safe.)
The GoZ function in CC3 should work after a restart of the app.
Please feel free to let us know if you have any further questions.
Best Regards
Technical Support
Reallusion Inc.
kathosdesign Jun 27, 2022
Same here, I am using the trial and cannot go past this GoZ error, don't really know what's I'm testing if I can't use ZBrush with cc4. I saw a number of people having this issue since a while ago but don't see any real official solution or explanation to why this is not working. Is this a version thing or is it purely based on luck?
Tried every "solution" I could find online but I guess this is not a very popular/well supported software afterall as most paying software would have cs follow after a couple of days.
Wasted a day on this, beyond frustrated and really wanted it to work...
Using Windows11, ZBrush 2022
1 2
