Votes
0
Product:
iClone 8
Version:
8.52
Status:
Assigned
Issue 11809
iClone crashes on basic building with BuildingGen
Hi. I just got BuildingGen and I'm trying it. I'm testing this set up (see image with 3 levels, 2x3 units and both front cut corners and 1 door), but with this simple settings in an empty project, iClone always crashes.
OS: Windows 11
  •  3
  •  65
Submitted byAndrés Moya Feb 14, 2025
COMMENTS (3)
Feedback Tracker Admin Feb 23, 2025
Hi Andrés Moya,
Thanks for your Feedback,
The issue can be successfully reproduced and has been reported.
JoePan
Reallusion
mrdopezart Feb 23, 2025
And I guess there will be no response to this as usual. As time has gone on it works worse and worse. Today I cant even make a 1 level building crashes every time. And this is just opening the plugin and running the most basic thing crashes. Crashes on my laptop with an I5 and a 4050 and the desktop with a I7 and a 4080. And the custom buildings are so iffy sometimes it will pull up a totally diff building no matter what I select
mrdopezart Feb 20, 2025
Having similar issues it almost always crashes if you use it more than once in a session
