I have found the same issue and was able to run both Character Creator (3.32) and iClone (7.82) once I turned multi monitor off. Please fix this soon as possible as a single monitor workflow is very very difficault. FYI: I have an NVIDIA RTX 2080 using 457.30 driver
I found that it was the smart database that was causing the problem. When I uninstalled that I was able to load beyond the splash. Of course, many of my items wouldn't load without it. Is there a way to roll back before that installation?
Hi Choyce7, Can you launch AP with hotfix version? Molly Reallusion
Yes,but there are maybe other problems. Molly Reallusion
Are you saying that having multi monitor's setup can cause the smart database to freeze?
Hi Choyce7, Please download the hotfix version and do as the readme,then try it again.Please let me know the result.Thank you. http://ftp.reallusion.com.tw/reallusionsupport/SG_InitialFreeze_Hotfix20201007.zip It still happens in some cases,eg. multi monitor Molly Reallusion
Hi Choyce7, Thank you for your feedback.Please provide your system information file to help us identify the problem. Attach the file in your next comment. You can use Private Comment if you want to keep it private.Your help is highly appreciated. Here is the description about how to get your system information file. https://www.reallusion.com/FeedBackTracker/Home/HowToGet Molly Reallusion
