Votes
Product:
Version:
1.0
Status:
Active
Issue 8829
exporting from the new auto rigging
24-8-2022
hi all
I have just tested the new auto rigging it is wonderful but it is in the early stages of development
only tested with fbx files into iclone 7 & 8
well, if you are using 7 pipeline then you have no trouble
as they come in as a T pose, if not converted
which it hard to apply motion
one has mention that --- mixamo. --- does as well then go with the flow on that
and give the team opportunity to develop their own style
I hope i have been helpful to all
from Alan
OS: Windows 10
  •  3
  •  697
Submitted byr78zj99 Aug 24, 2022
COMMENTS (3)
r78zj99 Aug 27, 2022
My comment
Hello again to all
Many thanks to the team
Still learning
Sorry about the video being removed
Just had the wonderful auto rigging in it early stages
And very thankful to the team
Being reading some common issues
1.	Check the capabilities of your machine like – RAM, CPU & so on
2.	Back compatibility issues because new complex model being send from cc4 to Iclone 7 doesn’t support motions in fbx format but the good news is. If you were a previous owner of the pipeline version then you are in luck. Check their timeline as to the reason why about integration.
 From Alan
r78zj99 Aug 25, 2022
yes, Soya
cc4 can support both avatar & fbx  -- see zip video
where as iclone 7 pipeline also can support  (in fbx)
from Alan
for whose using the old 7 pipeline see gif
being helpful to all
Feedback Tracker Admin Aug 25, 2022
Hi Alan,
I would like to remind you that when a FBX is loaded into an iC7 or iC8, its type will be a prop instead of a character. They can't apply the character's motions. However, you can use the CC4 characterize functions to turn these props into non-standard characters.
Soya
Reallusion
