Votes
0
Product:
Character Creator 3
Version:
3.42
Status:
Active
Issue 8007
autoLOD combine UVs Item
My CC3 crashed every time I try to using autoLOD with the settings Merge UVs -> By Item. I've tried it by Type and it works but for some reason it crashes when I select "by Item" Their is no error message shown. Also I tried reinstalling cc3 without any luck.
OS: Windows 10
  •  2
  •  673
Bug
Submitted bysnoogan1187 Jul 13, 2021
COMMENTS (2)
snoogan1187 Jul 16, 2021
I've tried mine and the default character with the same results. I've uninstalled cc3 and the pipeline plugin. Deleted that cc3 temp folder and cleaned registry. Reinstalled with same results using mine and default female character.
Feedback Tracker Admin Jul 14, 2021
Hi snoogan1187,
Thanks for your feedback.
We need more information to clarify the issue.
Did the issue happen on the same model? The default character have the same problem when doing AutoLOD? What export preset did you use?
Please provide your project to us. Allowing us to clarify issues.
If the file size is larger than 10MB, you can use cloud services such as Google Drive, Dropbox or OneDrive to make the files available to us and put the link in your comment.
You can use Private Comment if you want to keep it private.
Your help is highly appreciated.
Thanks
Melvin
Reallusion.
