Issue 7203
Zoom Opacity Problem
Hello,
Meshes disappear when zooming. I have reduced the situation to a minimum: Create Accessory adds an obj- file to the standard avatar. After reading Opacity jpg or prn file the effect occurs. If you zoom in on the head of the avatar, more and more hair will disappear. The effect is not limited to the attached example, but also appears with other hairstyles, but not with all of them. The author of the hairstyles is the same, the integration via obj files and the supply of Opacity "images". The effect changes its intensity when you turn the viewing angle.
The hair has several meshes. It gives the impression that the number of meshes plays a role.
best regards
Gerold Beck
Submitted bygerold.beck
Aug 30, 2020
