Hi massimorossa, It means that you're using the built-in goz button instead of goz plus plugin, it'll be better to use plugin version to avoid multimaterial problem when updating texture and normal back to Character Creator. There will be no difference if your subtool has only one material. You can find the update button under zplugin->CC GoZ Plus. Soya Reallusion
