Votes
0
Product:
CrazyTalk 8
Version:
8.13
Status:
Not Reproducible
Issue 7996
Using Teeth Settings causes garbage to appear in the projects window (Crazy Talk 8 Standard for Mac)
Every time I create a new 2d project in Crazy Talk 8 and Pro version, then display theTeeth Settings, the project gets corrupted. garbage appears in the project area. Sometimes, if I close the Teeth Settings, then use the Undo command, the garbage disappears, then I return to the Teeth Settings, make adjustments, close the Teeth Settings, then the garbage disappears and the head is properly updated with the correct teeth settings. However, other times this does not work. When I close the Teeth Settings, the garbage is still on the screen and using the Undo command does not work, so I have to close the project, open the project, try the teeth settings again. Sometimes this will work, other times I have to just delete the project and try importing a different head.
OS: Mac OS 10.15
  •  2
  •  2576
Bug
Submitted byscottdkorb Jul 7, 2021
COMMENTS (2)
Feedback Tracker Admin Nov 16, 2021
Hi scottdkorb,
Did this issue still exist?
We need more information in order to help you.
Allen
Reallusion
Feedback Tracker Admin Jul 8, 2021
Thank you for your feedback.
Please provide your ".ct7Project" file to help us identify the problem.
You can use cloud services such as Google Drive, Dropbox or OneDrive to make the files available to us and add the link in your next comment. you can use private comment if you want to keep it private.
Your help is highly appreciated.
Allen
Reallusion
