Votes
0
Product:
iClone 7
Version:
7.93
Status:
Active
Issue 11339
Unable to reinstall Smart Gallery in iClone 7.93
I am the only Administrator of my Desk Top PC. My problem is related to iClone 7.93.
Recently I had to unistall and re-install the program. I used last version of Reallusion Hub that apparently is correctly working. In Character Creator 3.44 Smart Gallery is present but it seems not to work properly. I spent a lot of time to understand the problems. Some time ago I have tried iClone 8, then afterward has been un-stalled due to the hi price I cannot afford at the moment. In my Pc is also regularly installed CC 4, that unfortunately is not compatible with iClone 7.93. I am just an amateur. Pls help me in solving the Smart Gallery problem.
Thank you.
Gianni Godi
OS: Windows 10
  •  4
  •  271
Submitted bygiannigodi Jun 1, 2024
COMMENTS (4)
giannigodi Jun 6, 2024
Many thanks Lilian.
1 -Following your directions, I solved the problem. However, I must point out that in the meantime rummaging through my Desk Top I discovered that I had a backup file of the SMART GALLERY Package. So I installed SMART GALLERY the old-fashioned way without using Reallusion Hub.
2- However, there is still a problem regarding the complete re-installation of the Popcorn package: base + Popcorn FX Super Tools that I bought long ago for iClone 7.93. I was able to install Basic Popcorn. If I open PopcornFX Super Tools, it tells me to buy or try. (See Photos).
I ask: why should I buy a new package (already purchased) of PopcornFX Super Tools that is only good for iClone 8?
Thank You
giannigodi Jun 2, 2024
A few minutes ago I uninstalled icon 7.93. For uninstallaral I had to use the Windows application as in Reallusion Hub it was not possible. He told me that the existing installation had not been done correctly. So I used the Windows uninstall. I then reinstalled icone 7.93 with Reallusion Hub. He was unable to install Smart Gallery- See photo.
Thank you
Nome dispositivo	Gianni-PC
Processore	Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz   3.40 GHz
RAM installata	16,0 GB (15,9 GB utilizzabile)
ID dispositivo	8116A35E-629E-4EF8-A882-A21D889F086D
ID prodotto	00330-80000-00000-AA294
Tipo sistema	Sistema operativo a 64 bit, processore basato su x64
Penna e tocco	Nessun input penna o tocco disponibile per questo schermo
Edizione	Windows 10 Pro
Versione	22H2
Data installazione:	‎06/‎05/‎2024
Build sistema operativo	19045.4412
Esperienza	Windows Feature Experience Pack 1000.19056.1000.0
Resoconto informazioni di sistema NVIDIA creato il: 06/01/2024 12:00:18
Nome sistema: GIANNI-PC
[Schermo]
Versione DirectX:	12.0
Processore GPU:		NVIDIA GeForce GTX 1080
Versione del driver:	555.85
Tipo di driver:		DCH
Livello funzione Direct3D:	12_1
Nuclei CUDA:		2560
Clock principale:	1607 MHz
Frequenza dei dati di memoria:	10.01 Gbps
Interfaccia memoria:	256 bit
Larghezza di banda memoria:	320.32 GB/s
Memoria grafica totale disponibile:	16322 MB
Memoria video dedicata:	8192 MB GDDR5X
Memoria video di sistema:	0 MB
Memoria di sistema condivisa:	8130 MB
Versione BIOS video:	86.04.60.00.43
IRQ:			Not used
Bus:			PCI Express x16 Gen3
ID dispositivo:		10DE 1B80 859B1043
Numero di parte:	G413 0000
[Componenti]
nvui.dll		8.17.15.5585		NVIDIA User Experience Driver Component
nvxdplcy.dll		8.17.15.5585		NVIDIA User Experience Driver Component
nvxdbat.dll		8.17.15.5585		NVIDIA User Experience Driver Component
nvxdapix.dll		8.17.15.5585		NVIDIA User Experience Driver Component
NVCPL.DLL		8.17.15.5585		NVIDIA User Experience Driver Component
nvCplUIR.dll		8.1.940.0		NVIDIA Control Panel
nvCplUI.exe		8.1.940.0		NVIDIA Control Panel
nvWSSR.dll		32.0.15.5585		NVIDIA Workstation Server
nvWSS.dll		32.0.15.5585		NVIDIA Workstation Server
nvViTvSR.dll		32.0.15.5585		NVIDIA Video Server
nvViTvS.dll		32.0.15.5585		NVIDIA Video Server
nvDispSR.dll		32.0.15.5585		NVIDIA Display Server
Detailed sequence of Smart Gallery installation in iClone 7.93
Opening iClone via Reallusion Hub>is OK>opening a Project where there is a still Avatar> Applying an animation>example Heidi perform Catwalk> (see attached photos)
