Votes
0
Product:
Character Creator 3
Version:
3.0
Status:
Not Reproducible
Issue 5199
Transformer crashes upon loading TIF and/or bump/Normal maps
If the ini file for the baking of the textures contains a .TIF file (at least in the eyes -- I haven't verified if this is true elsewhere although I suspect it is) it will crash CC3 (which exits without explanation). It ALSO seems to crash if the ini file contains both bump and normal maps for the same material (haven't *quite* verified this one). Here's a test case to play with:
https://mega.nz/#!J3BEkYLS!2M5fR_bc4K7aqMUYaYOvm7APqB5-u-OrIkOXfps0qR4
When I edit the ini and remove the TIF references it gets past the eyes/teeth message, and then crashes further on. When I remove all the bump map references it goes all the way through.
OS: Windows 10
  •  3
  •  980
Bug
Submitted byKelleytoons Oct 2, 2018
COMMENTS (3)
Feedback Tracker Admin Oct 4, 2018
Hi, Kelleytoons,
I have downloaded your file.
Thank you.
Reallusion
Kelleytoons Oct 3, 2018
Try this (sorry -- was trying to clean things up):
https://mega.nz/#!5vIU0CYI!VWvsZeyWBjcoUCEFkDP3mS1woJnMOuLJ3EQlKcQbQHE
Feedback Tracker Admin Oct 3, 2018
Hi, Kelleytoons,
Please check the link in your post, the file is not there.
Thank you.
Reallusion
