I installed Iclone 7 trial. It's not opening whenever I run it. It stops after showing Iclone 7 image for seconds. I clicked icon in installed folder and run it on hub, but it's not working. I searched solutions for this issue and tried all tips. Could anyone suggest how to fix this issue? I really want to check trial version before buying it.
Hi jin_868478,
Can you provide the startup log to us?
Reallusion
Feedback Tracker Admin
Thank you for your feedback.
Please provide your system information file and iClone 7 startup log file to help us identify the problem.
Here is the description about how to get your system information file.
https://www.reallusion.com/FeedBackTracker/Home/HowToGet
Download the zip file with the link below, inside the zip you can find the description about how to generate the startup log file.
https://goo.gl/YgVYhF
Please attach these files in your next comment.
Thank you for your help.
Reallusion
You are going to edit a submitted issue. This issue will be changed to private draft mode until you click submit again. Are you sure?
