Hi attila.pasztor, I hope you will be able to provide the information. Reallusion.
Hi attila.pasztor, Since your issue is special and we still can't reproduce it at our end, we require more information. Reallusion.
Thank you for your feedback. Please update your display driver first, and run CrazyTalk Animator 3 again, see if this issue can be solved? If not, please provide your DxDiag file and the CrazyTalk Animator 3 crash dump file for further checking? To get the DxDiag file: 1. Select the "Start" menu, click "run" or press <Win Key> + <R>. 2. Input "dxdiag" & click "ok". 3. It will check your system for a while, after finish, click "save all information". 4. Save "DxDiag.txt". To get the CrazyTalk Animator 3 crash dump file: Go to "C:\Users\<User Name>\AppData\Local\Temp\Reallusion" folder, and find a file with the name started with "CTA" and the file extension is ".dmp". For example: "CTAv3.0-[Nov 9 2016]-20161110-105718-4864-724.dmp" There should be only one CTA dump file, if you found more than one, please get the latest file. You can use cloud services such as Dropbox or OneDrive to make the files available to us and email the link with "FT2305" in the email title to feedbacktrackeradmin@reallusion.com. Your help is highly appreciated. Reallusion
