Hi Isazforms, Because the character is wearing high-heel, so she stood tiptoe upon the floor already. Then the pose that you apply to her also bent her foot much further, so that you will see the awkward situation. Currently, you can use the function in CC3's Modify Panel / Motion Pose tab / Edit Pose to adjust the right pose that you want. You can check the attached image, please let us know if this work for you! Reallusion.
Yes! the bending is the problem.
Hi Isazforms, Thanks for the reply! Do you mean the character's foot is bending awkwardly? Reallusion.
Hi Isazforms, Thanks for your feedback! In order to check this issue, please provide this ccProject to us, so that we can investigate problem properly! You can attach file in your next comment. If the file size is larger than 10MB, you can use cloud services such as Google Drive, Dropbox or OneDrive to make the files available to us and put the link in your comment. You can use Private Comment if you want to keep it private. Your Help is highly appreciated! Reallusion.
