Votes
3
Product:
Cartoon Animator 4
Version:
4.02
Status:
Active
Issue 6150
Set up default Frame size in the Preferences
I use 720p (1280x720) frame size a lot. Unfortunately the only way to set frame size is through Render window for each project. Often times when I start a new project I forget to set the frame size until the project is ready to render and then changing frame size messes up the entire scene so I have to adjust all the camera movements, all the framing of the characters, etc. Needless to say it's a hassle.
It would be really great to be able to set up default Frame Size in Preferences. OR in the very least make the software prompt you to select frame size when starting a new project.
OS: Mac OS 10.14
  •  3
  •  1066
Submitted bycandlelight2007 Aug 5, 2019
COMMENTS (3)
agwiazda Jan 15, 2022
Good suggestion. I also add a problem with the number of frames per second. I am from Europe and our assembly includes designs of 1 s = 25 frames. In this program there is only the option 1s = 30 frames
Deborah Hearne Jun 16, 2021
I want this added too.  I don't understand why the frame size is in render rather than in the project settings.  Having it under the project settings makes it more convenient for the user.
Macdonut Aug 8, 2019
Excellent suggestion. Been there as it is easy to forget to change at the beginning.
