Issue 5897
Scaling issue of saved animated Prop . . .
This is getting ridiculous. Same Project file, 913Mb. I create an animated wheel using a Dummy object as shown, a cube. I add that Prop to my Props so I can drag-n-drop another copy into the Scene. When I do this, as the picture attached shows, the animated wheel is "scaled" out of proportion and is now larger than the stupid room it came from.
So, once again, I have to either: rescaled the wheel or select it again and drag it to the place I need it. That, then, becomes another problem as the Perform I added to this wheel goes out of whack and tries to go back to it's original location. I removed the Object animation, but when I hit Perform, you can see the wheel slowly move back to it's original location.
Again, another "problem" that has created another "problem". It is possible that you guys can add a "Lock" checkbox next to each Axis so you can stop it from moving in the wrong direction(s)?
Submitted byTucsonDoobie
Apr 5, 2019
