Votes
Product:
iClone 7
Version:
7.92
Status:
Active
Issue 8099
Root motion not exported in FBX
Going off from a 2017 thread about root motion not being exported with FBX files, I have recently experienced that this issue still exists. For good measure I have tried a number of different things, including enabling/disabling Reset root motion, selecting both Unreal and Unity presets, and even trying to re-export the resulting FBX using 3DXchange, which results in the animation being removed altogether (what?).
Can anyone else confirm the persistent status of this issue, or is there a setting or step that I am missing when trying to export by animations into FBX?
OS: Windows 10
  •  3
  •  1099
Submitted byfabiobasile Sep 9, 2021
COMMENTS (3)
vincenzo_574121 Jan 24, 2022
Sorry fabio how you solved the root problem ? I am having the same issue right now and can't find a proper solution
fabiobasile Oct 9, 2021
Since my last inquiry, I was ultimately able to export the root bone, but now i am faced with a different issue, as all of my turning animations don't work properly with UE4.
To illustrate my new issue, i have attached a simple diagram. I am trying to generate an animation of my character walking in circle, which i plan to use in my root motion animation in UE4. In IClone, i generate my character animation witth the root bone aligned to the position of the first frame of the animation, but that is not what i want. I want my character to start the motion along the circular path surrounding the world's origin, in a similar way as Mixamo does.
Please find one of the files affected in the following link to my Google Drive:
https://drive.google.com/file/d/1UFX7aPZ5nncADGGNAoyqEh03BUNKjaFb/view?usp=sharing
Thanks!
Feedback Tracker Admin Oct 8, 2021
Hi fabiobasile,
Please provide your project file to help us identify the problem.You can use cloud services such as Google Drive, Dropbox or OneDrive to make the files available to us and put the link in your comment. You can use Private Comment if you want to keep it private.
Molly
Reallusion
