Votes
0
Product:
Character Creator 3
Version:
3.41
Status:
Not a Bug
Issue 7825
Reset button does not work when "Edit facial" dialog has been closed once
Steps to reproduce:
- run "Modify -> Edit facial" command
- open Modify tab
- click Mouth section
- find "Mouth open" slider and drag it to 100
- close the "Edit facial" dialog
- again run "Modify -> Edit facial" command
- click the Reset button
Actual result:
- the "Mouth open" slider is not reset to 0, the mouth does not close, and "Reset" button gets disabled
Expected result:
- Reset button should reset all the sliders to defaults even after the "Edit facial" dialog has been closed before
- Reset button should become disabled only when all the sliders are actually at their default values
OS: Windows 10
  •  1
  •  577
Bug
Submitted bymidix Apr 15, 2021
COMMENTS (1)
Feedback Tracker Admin Apr 23, 2021
Hi midix,
Thanks for your feedback!
The reset btn means you can reset the facial result back to the status when you enter the mode.
If you want to back to all 0 result, you can switch to Muscle tab and click Default Key btn.
Calvin
Reallusion.
