Votes
0
Product:
iClone 7
Version:
7.61
Status:
Assigned
Issue 6276
Rendering Issue
I still have problems rendering hair I create using DAZ hair, but, is not so noticeable in animation.
Attached rendered DAZ hair. There is a line that goes across the rendered image. I have tried it in various render formats (png, jpg) and different resolutions, but, all the same.
OS: Windows 7
  •  7
  •  2237
Submitted bysales_43 Sep 23, 2019
1 2
COMMENTS (7)
WayN Oct 15, 2019
Hi Sales,
I've sent a message to your email. Please take a look, Thank you : )
Wayn
sales_43 Oct 14, 2019
Hi,
Thanks for your response, but, I don't have Win10, I'm using Win7
Regards
WayN Oct 14, 2019
Hi,
Have you tried the windows 10 + NVIDIA GPU (GTX 9xx series and above) combo ?
I haven't encounter a case in which it didn't work ?
If you aren't sure what GPU is installed, in win 10, you can open task manager (hotkey: ctrl + shift + esc) and click on the 'performance' tab, then click on GPU 0, the name of the GPU will be on the upper right corner
Thanks
sales_43 Oct 13, 2019
Hi,
I have tried all your suggestions to no avail.
Using Alpha Threshold is not a solution as it destroys the essence of the quality of DAZ hair. It changes it from hair to spaghetti strands.
Regards
WayN Oct 8, 2019
Hi sales,
Could you try to shrink iClone's viewport as small as possible, and uncheck the 'Optimize with Full Screen Render' option in the Render section, and then render the image again ?
Is the result ok ?
If it is still not ok, do you have a PC with windows 10 to try ?  iClone has a fix for this in windows 10 + NVIDIA (GTX 9xx series and above) or Intel GPU
If you don't have it to try, one workaround is to check the 'Alpha Threshold' checkbox under material section and adjust the slider value (may be start with 10), but this sacrifices the transparent visual quality
1 2
