Votes
Product:
iClone 7
Version:
7.7
Status:
Assigned
Issue 6441
Rendering 2x slower
My post here:
https://forum.reallusion.com/427430/OFFICIAL-iClone-77-Issues-Thread?PageIndex=2#bm427692
I don't want to stay with 7.6.1 cause I cannot use the new program that came out, I am assuming,
So I made a comparison, and see the difference.
Both are set for High preview.
If I change it to minimal, 7.6.1 is very fast. 7.7 is still slow.
With 7.6.1 it goes very fast.. and moving through the scrubber, and the update to Iray preview render is almost instantly
1.14 MATCNV rend info : found 6215 textures, 79 lambdas (6 unique)a
1.14 IRAY rend info : Computing 21 flux compensation factors took 0.009 seconds
1.14 IRAY rend info : Emitter geometry import (85 light sources with 45012 triangles, 1 instance) took 0.02s
1.14 IRAY rend info : Updating lights.
1.14 IRAY rend info : Updating object flags.
1.14 IRAY rend info : Updating caustic portals.
1.14 IRAY rend info : Updating decals.
1.14 IRAY rend info : Rendering...
1.5 IRAY rend info : Using device 0 to build data for host
1.5 IRAY rend info : Importing lights for motion time 0
1.5 IRAY rend info : Initializing light hierarchy.
1.5 IRAY rend info : Light hierarchy initialization took 1.63s
1.4 IRAY rend info : CPU: Scene processed in 1.749s
1.6 IRAY rend info : JIT-linking wavefront kernel in 0.250s
1.6 IRAY rend info : JIT-linking mega kernel in 0.048s
1.8 IRAY rend info : CUDA device 0 (GeForce GTX 1070): Scene processed in 2.052s
1.8 IRAY rend info : CUDA device 0 (GeForce GTX 1070): Allocated 1.45164 GiB of work space (1761k active samples in 0.000s)
1.14 IRAY rend info : Received update to 00001 iterations after 2.343s.
1.14 IRAY rend info : Received update to 00002 iterations after 2.673s.
1.14 IRAY rend info : Received update to 00003 iterations after 2.945s.
1.14 IRAY rend info : Received update to 00004 iterations after 3.265s.
1.14 IRAY rend info : Received update to 00005 iterations after 3.568s.
1.14 IRAY rend info : Received update to 00006 iterations after 3.856s.
1.14 IRAY rend info : Received update to 00007 iterations after 4.151s.
1.14 IRAY rend info : Received update to 00008 iterations after 4.458s.
1.14 IRAY rend info : Received update to 00009 iterations after 4.753s.
1.14 IRAY rend info : Received update to 00010 iterations after 5.051s.
1.14 IRAY rend info : Received update to 00011 iterations after 5.346s.
1.14 IRAY rend info : Received update to 00012 iterations after 5.646s.
1.14 IRAY rend info : Received update to 00013 iterations after 5.936s.
1.14 IRAY rend info : Received update to 00014 iterations after 6.236s.
1.14 IRAY rend info : Received update to 00015 iterations after 6.526s.
1.14 IRAY rend info : Received update to 00016 iterations after 6.832s.
1.14 IRAY rend info : Received update to 00017 iterations after 7.144s.
1.14 IRAY rend info : Received update to 00018 iterations after 7.442s.
1.14 IRAY rend info : Received update to 00019 iterations after 7.748s.
1.14 IRAY rend info : Received update to 00020 iterations after 8.029s.
1.14 IRAY rend info : Maximum number of samples reached.
1.14 IRAY rend info : Updating geometry.
1.14 IRAY rend info : Using OptiX Prime ray tracing (5.0.1).
1.14 IRAY rend info : Importing scene graph.
1.14 IRAY rend info : Importing geometry for motion time 0
1.14 IRAY rend info : Geometry import (1 object with 215k triangles, 1 instance yielding 215k triangles) took 0.103505
1.14 IRAY rend info : Updating materials.
1.14 MATCNV rend info : Material instance '01-Default(0)' uses MDL JIT compilation.
-- cut a bunch of the same things
1.14 IRAY rend info : Computing 21 flux compensation factors took 0.011 seconds
1.9 IRAY rend info : Using device 0 to build data for host
1.9 IRAY rend info : Importing lights for motion time 0
1.9 IRAY rend info : Initializing light hierarchy.
1.9 IRAY rend info : Light hierarchy initialization took 1.68s
1.4 IRAY rend info : CPU: Scene processed in 1.798s
1.5 IRAY rend info : JIT-linking wavefront kernel in 0.251s
1.5 IRAY rend info : JIT-linking mega kernel in 0.044s
1.8 IRAY rend info : CUDA device 0 (GeForce GTX 1070): Scene processed in 2.107s
1.8 IRAY rend info : CUDA device 0 (GeForce GTX 1070): Allocated 1.60242 GiB of work space (1944k active samples in 0.000s)
1.14 IRAY rend info : Received update to 00001 iterations after 2.406s.
1.14 IRAY rend info : Received update to 00002 iterations after 2.746s.
1.14 IRAY rend info : Received update to 00003 iterations after 3.051s.
1.14 IRAY rend info : Received update to 00004 iterations after 3.353s.
1.14 IRAY rend info : Received update to 00005 iterations after 3.657s.
1.14 IRAY rend info : Received update to 00006 iterations after 3.966s.
1.14 IRAY rend info : Received update to 00007 iterations after 4.271s.
1.14 IRAY rend info : Received update to 00008 iterations after 4.575s.
1.14 IRAY rend info : Received update to 00009 iterations after 4.876s.
1.14 IRAY rend info : Received update to 00010 iterations after 5.179s.
1.14 IRAY rend info : Received update to 00011 iterations after 5.481s.
1.14 IRAY rend info : Received update to 00012 iterations after 5.789s.
1.14 IRAY rend info : Received update to 00013 iterations after 6.088s.
1.14 IRAY rend info : Received update to 00014 iterations after 6.369s.
1.14 IRAY rend info : Received update to 00015 iterations after 6.697s.
1.14 IRAY rend info : Received update to 00016 iterations after 7.006s.
1.14 IRAY rend info : Received update to 00017 iterations after 7.309s.
1.14 IRAY rend info : Received update to 00018 iterations after 7.588s.
1.14 IRAY rend info : Received update to 00019 iterations after 7.915s.
1.14 IRAY rend info : Received update to 00020 iterations after 8.190s.
---- Same thing done with 7.7 Scrubbing is very slow, while it's doing a preview
1.6 IRAY rend info : Using device 0 to build data for host
1.6 IRAY rend info : Importing lights for motion time 0
1.6 IRAY rend info : Initializing light hierarchy.
1.6 IRAY rend info : Light hierarchy initialization took 0.35s
1.20 IRAY rend info : CPU: Scene processed in 0.470s
1.18 IRAY rend info : JIT-linking wavefront kernel in 0.101s
1.18 IRAY rend info : JIT-linking mega kernel in 0.051s
1.19 IRAY rend info : CUDA device 0 (GeForce GTX 1070): Scene processed in 0.611s
1.19 IRAY rend info : CUDA device 0 (GeForce GTX 1070): Allocated 1.6875 GiB of work space (2048k active samples in 0.000s)
1.14 IRAY rend info : Received update to 00001 iterations after 1.495s.
1.14 IRAY rend info : Received update to 00002 iterations after 2.527s.
1.14 IRAY rend info : Received update to 00003 iterations after 3.497s.
1.14 IRAY rend info : Received update to 00004 iterations after 4.611s.
1.14 IRAY rend info : Received update to 00005 iterations after 5.579s.
1.14 IRAY rend info : Received update to 00006 iterations after 6.489s.
1.14 IRAY rend info : Received update to 00007 iterations after 7.572s.
1.14 IRAY rend info : Received update to 00008 iterations after 8.652s.
1.14 IRAY rend info : Received update to 00009 iterations after 9.531s.
1.14 IRAY rend info : Received update to 00010 iterations after 10.538s.
1.14 IRAY rend info : Received update to 00011 iterations after 11.483s.
1.14 IRAY rend info : Received update to 00012 iterations after 12.446s.
1.18 IRAY rend info : CUDA device 0 (GeForce GTX 1070): Allocated 17.6649 MiB for frame buffer
1.3 IRAY rend info : CUDA device 0 (GeForce GTX 1070): Allocated 17.6649 MiB for frame buffer
1.0 DB db warn : Committing transaction while transaction is blocked!
1.14 IRAY rend info : Geometry import (1 object with 177k triangles, 1 instance yielding 177k triangles) took 0.090467
1.14 MATCNV rend info : Material instance '01-Default' uses MDL JIT compilation.
1.14 MATCNV rend info : Material instance 'elevatorMat_emit' uses MDL JIT compilation.
1.14 MATCNV rend info : Material instance 'dummyLight(0)' uses MDL JIT compilation.
1.14 MATCNV rend info : Material instance 'refractiveGlass(20)' uses MDL JIT compilation.
1.14 MATCNV rend info : Material instance 'refractiveGlass(21)' uses MDL JIT compilation.
1.14 IRAY rend info : Emitter geometry import (66 light sources with 7316 triangles, 1 instance) took 0.00s
1.5 IRAY rend info : Light hierarchy initialization took 0.34s
1.19 IRAY rend info : CPU: Scene processed in 0.443s
1.18 IRAY rend info : JIT-linking wavefront kernel in 0.092s
1.18 IRAY rend info : JIT-linking mega kernel in 0.042s
1.20 IRAY rend info : CUDA device 0 (GeForce GTX 1070): Scene processed in 0.584s
1.20 IRAY rend info : CUDA device 0 (GeForce GTX 1070): Allocated 1.6875 GiB of work space (2048k active samples in 0.000s)
1.2 IRAY rend info : CUDA device 0 (GeForce GTX 1070): Allocated 17.6649 MiB for frame buffer
1.6 IRAY rend info : CUDA device 0 (GeForce GTX 1070): Allocated 17.6649 MiB for frame buffer
1.14 IRAY rend info : Geometry import (1 object with 177k triangles, 1 instance yielding 177k triangles) took 0.088252
--- cut the same thing.. which seems to be happening for every movement.
1.5 IRAY rend info : Light hierarchy initialization took 0.35s
1.19 IRAY rend info : CPU: Scene processed in 0.525s
1.6 IRAY rend info : JIT-linking wavefront kernel in 0.113s
1.6 IRAY rend info : JIT-linking mega kernel in 0.049s
1.20 IRAY rend info : CUDA device 0 (GeForce GTX 1070): Scene processed in 0.679s
1.14 IRAY rend info : Received update to 00001 iterations after 1.658s.
1.14 IRAY rend info : Received update to 00002 iterations after 2.786s.
1.14 IRAY rend info : Received update to 00003 iterations after 3.758s.
1.14 IRAY rend info : Received update to 00004 iterations after 4.663s.
1.14 IRAY rend info : Received update to 00005 iterations after 5.636s.
1.14 IRAY rend info : Received update to 00006 iterations after 6.386s.
1.2 IRAY rend info : CPU: Allocated 2.20259 MiB for frame buffer
1.23 IRAY rend info : CUDA device 0 (GeForce GTX 1070): Allocated 18.2229 MiB for frame buffer
1.14 IRAY rend info : Received update to 00007 iterations after 7.245s.
1.14 IRAY rend info : Received update to 00008 iterations after 7.966s.
1.14 IRAY rend info : Received update to 00009 iterations after 8.705s.
1.14 IRAY rend info : Received update to 00010 iterations after 9.417s.
1.14 IRAY rend info : Received update to 00011 iterations after 10.129s.
1.14 IRAY rend info : Received update to 00012 iterations after 10.821s.
1.14 IRAY rend info : Received update to 00013 iterations after 11.533s.
1.14 IRAY rend info : Received update to 00014 iterations after 12.251s.
1.18 IRAY rend info : CPU: Allocated 1.81117 MiB for frame buffer
1.6 IRAY rend info : CUDA device 0 (GeForce GTX 1070): Allocated 18.6143 MiB for frame buffer
1.14 IRAY rend info : Received update to 00015 iterations after 12.953s.
1.14 IRAY rend info : Received update to 00016 iterations after 13.645s.
1.14 IRAY rend info : Received update to 00017 iterations after 14.182s.
1.14 IRAY rend info : Received update to 00018 iterations after 14.776s.
1.14 IRAY rend info : Received update to 00019 iterations after 15.370s.
1.14 IRAY rend info : Received update to 00020 iterations after 15.965s.
OS: Windows 10
  •  0
  •  1132
Bug
Submitted bypka4916 Nov 20, 2019
COMMENTS (0)
