Votes
0
Product:
iClone 8
Version:
8.33
Status:
Released in 8.4
Issue 10934
RIFacialDevice.ProcessData seems to be broken in 8.33
RIFacialDevice.ProcessData seems not to work any more, and it doesn't return any errors either.
The script in this post can be used to reproduce this problem,
https://forum.reallusion.com/523684/How-to-write-a-facial-mocap-plugin
OS: Windows 11
  •  4
  •  368
Bug
Submitted bysunnyviewtech Nov 21, 2023
COMMENTS (4)
sunnyviewtech Mar 20, 2024
Thank you for the help, we will fix our plugin accordingly!
Feedback Tracker Admin Mar 20, 2024
Thanks. I will close it.
Hi, we have got it working successfully! Please close this issue, thank you for your help.
Hope to solve your problem!
Molly
Reallusion
Feedback Tracker Admin Mar 19, 2024
Hi sunnyviewtech,
The sample code didn't account for different numbers of expressions for characters, which caused some errors.
We've updated the Sample Code, so give it another shot!
Molly
Reallusion
sunnyviewtech Mar 2, 2024
Hi, you can check the AppData\Local\Reallusion\RLDownloads folder to see if the previous versions are still there
CYBL Mar 1, 2024
Is there a way to roll back to a previous version while this is being looked into. Since I can't run MotionLIVE in the webcam at the same time as the plugin, I am currently stuck without any facial capture.
