Issue 7755
Problems with Smart Gallery Hotfix.zip
"Please read the "HowTo.txt" in the .zip before updating."
First of all there is no "HowTo.txt" file to read in the zip.
"The hotfix install flow should be:
DONE- 1. Switch the Smart Gallery to Online mode.
DONE- 2. Close program
TRIED- 3. Run the Hotfix .bat
Ran 1.13HotFix_CC340.bat as administrator, this is what I got:
C:\WINDOWS\system32>set HOST="localhost"
C:\WINDOWS\system32>set PORT=11810
C:\WINDOWS\system32>set USERNAME= "reallusion"
C:\WINDOWS\system32>set DBNAME="cc3"
C:\WINDOWS\system32>set POSTGRES_BIN="C:\Program Files\Common Files\Reallusion\PostgreSQL\bin"
C:\WINDOWS\system32>"C:\Program Files\Common Files\Reallusion\PostgreSQL\bin"\pg_ctl.exe -o "-p 11810" start -D C:\ProgramData\Reallusion\CMS
pg_ctl: another server might be running; trying to start server anyway
waiting for server to start....2021-03-29 13:55:43.409 PDT [12148] FATAL: lock file "postmaster.pid" already exists
2021-03-29 13:55:43.409 PDT [12148] HINT: Is another postmaster (PID 1324) running in data directory "C:/ProgramData/Reallusion/CMS"?
stopped waiting
pg_ctl: could not start server
Examine the log output.
C:\WINDOWS\system32>"C:\Program Files\Common Files\Reallusion\PostgreSQL\bin"\psql.exe -h "localhost" -p 11810 -U "reallusion" -d "cc3" -q -f "C:\WINDOWS\system32\recover_CC.sql"
C:/WINDOWS/system32/recover_CC.sql: No such file or directory
C:\WINDOWS\system32>move "C:\ProgramData\Reallusion\ContentManager\ExternalBatchSync\Character Creator\340\RemoveCidList.txt" "C:\ProgramData\Reallusion\ContentManager\ExternalBatchSync\Character Creator"
The system cannot find the file specified.
C:\WINDOWS\system32>call ".\OnlineCC.bat"
'".\OnlineCC.bat"' is not recognized as an internal or external command,
operable program or batch file.
C:\WINDOWS\system32>pause
Press any key to continue . . .
"4. Open the program and click Refresh manually."
Tried this anyways but still no different results.
Submitted bySnarp Farkle
Mar 29, 2021
