Votes
0
Product:
iClone 7
Version:
7.93
Status:
Closed
Issue 8349
Problems after making a character invisible
(See video)
I have a little seen simulation a bus stop. The bus pulls in and blocks the characters. I then make the characters invisible. Everything looks fine. But, I did rewind and reran the scene looking for problems, and my main characters hair physics go wild. While I was able to work around this problem, it may be something you need to fix.
Video Link:
https://www.dropbox.com/s/u125zztcyemmrjx/Visbility.mp4?dl=0
Project file:
https://www.dropbox.com/s/j3qs0k4ttsf1c66/c_hair.iProject?dl=0
Also I have attached my system info
OS: Windows 11
  •  2
  •  1160
Bug
Submitted bybobu2357 Feb 5, 2022
COMMENTS (2)
bobu2357 Feb 18, 2022
I already knew that.  I just thought you would be interested in the problem.
Feedback Tracker Admin Feb 18, 2022
Hi bobu2357,
Every time you play the project, the clothes and hair will be simulated once, so the results will be different.You can check "Soft Cloth" and "Bake Animation" in Project panel from Edit menu.A vertex Animation clip will be generated when you play the project.If you are not satisfied with the simulation result, you can delete the vertex animation clip and simulate again.
Molly
Reallusion
