Votes
0
Product:
iClone 7
Version:
7.41
Status:
Active
Issue 5885
Paths are unusable now
I have attached a video showing how even simple paths are not usable. In earlier versions paths worked fine, now the function might as well be removed!
Link:
https://www.dropbox.com/s/ouwvol8viddxw04/Paths.wmv?dl=0
OS: Windows 10
  •  6
  •  1916
Bug
Submitted bybobu2357 Mar 31, 2019
1 2
COMMENTS (6)
Feedback Tracker Admin Jun 10, 2019
Hi bobu2357,
If you want to create a straight path,you can press "Shift" when you create path.
Molly
Reallusion
bobu2357 May 27, 2019
A new example.  On the path to the left the avatar is given to "walk to" the path.  When the avatar gets to the path there is a jerky change of direction.  On the example to the left the avatar is "following the path.  At the starting point the avatar is pointed away from the path (follow box is -Y), by the end of the path she looks ok.  More noticeable on the right the path line is not straight even though it was created straight. The link to this example is : https://www.dropbox.com/s/yl3ujydczuz1fvg/Path_creation.mp4?dl=0
A second example shows how the paths are curved, even though they were created as straight : https://www.dropbox.com/s/norpd4hzvljqizk/pathcreationStill.jpg?dl=0
A third example shows how trying to create a straight path ends up with a curve : https://www.dropbox.com/s/yl3ujydczuz1fvg/Path_creation.mp4?dl=0
Feedback Tracker Admin May 27, 2019
Hi bobu2357,
I can't reproduce this issue.Can you provide the project file in your video?
Molly
Reallusion
1 2
