Issue 5430
Path Tool - option to retain current position/coordinates of object/avatar once released from the path
PATH tool
Please add an option for the object/avatar to remain in position when released from a path.
At the moment, as soon as you release an object/avatar part way along or at the end of a path, it jumps back to the beginning of the path. There doesn't seem to be an option to prevent this. iClone ignores any transform keys.
I have received some helpful suggestions from fellow iClone users in regards to workarounds (ie link a dummy prop to the path and then attach the object/avatar to this object), but surely we shouldn't have to resort to band-aid fixes ? There should be an option simply for the object to remain in place when released from the path ?
I tend to do everything to avoid using PATH because it isn't very friendly to use in this regard.
Submitted byDarren01
Nov 30, 2018
