Issue 1985
PNG settings are reversed
From the online manual: Preferences > System Section > Texture Launch Settings
After choosing which external editor you want to use, you specify "PNG with Alpha" or "PNG".
According to the documentation, the alpha option should open a single, composite editor window, while the plain option should open a split editor window.
In actual fact, the results are reversed. I have repeated swapping this setting several times and the results are consistent.
Submitted bygarylearntech
Jan 3, 2017
