Votes
0
Product:
iClone 7
Version:
7.61
Status:
Released in 7.7
Issue 6282
Opacity map shows in transparent object with GI on and opacity set <30
With GI activated. If you have an object with a material that has a opacity map placed behind a non-transparent object and put a transparent object in front of this with opacity set<30, then the opacity map of the object at the back is visible in the translucent object at the front.
The solid object in between only emphasizes the effect and is not part of the issue but makes it more apparent. In scenes with windows this causes some x-ray like effect.
Attached two screenshots - one with 29% and the other with 30% opacity.
I was unable to generate the system info as your tool crashed at 66% - see screenshot.
OS: Windows 10
  •  3
  •  1942
Submitted byelMartino Sep 24, 2019
COMMENTS (3)
Feedback Tracker Admin Oct 9, 2019
Hi elMartino,
I have got your file, we will check this issue.
Thanks for your help.
Molly
Reallusion
elMartino Oct 8, 2019
Hi Molly,
I did not save that scene but created a similar one and attached it.
Feedback Tracker Admin Oct 8, 2019
Thank you for your feedback.
Please provide your your project file to help us identify the problem.Attach the file in your next comment. If the file size is larger than 10MB, you can use cloud services such as Google Drive, Dropbox or OneDrive to make the files available to us and put the link in your comment.
You can use Private Comment if you want to keep it private.
Your help is highly appreciated.
Molly
Reallusion
