Issue 213
Object rotated unexpectedly when the object has rotate transform key and pick a path
STEPS TO REPRODUCE
1. Launch iClone 6
2. Apply a project using rotate transform key and pick path
3. Move current line to any frame, pick the object, right-click and choose Path > Pick Path, then select grid origin
5. Launch Timeline > Object > Constraint > Path, move current line to any frame
ACTUAL RESULT
The object rotated unexpectedly
EXPECTED RESULT
The length of Transform is changed to 10 frames, so the object can behave correctly
Submitted byFeedback Tracker Admin
Apr 6, 2016
