Votes
Product:
iClone 6
Version:
6.53
Status:
Active
Issue 1928
NOT SOLVED - Issue 891 Hiding Paths should make them Unselectable.
Let's try again. Hiding a Path should make it Unselectable.
When you hide a typical object in your scene, say a sphere or avatar, YOU CAN NO LONGER SELECT IT IN THE VIEWPORT. This is correct behaviour.
When you hide a PATH in your scene, (a path!), YOU CAN STILL SELECT IT IN THE VIEWPORT. EVEN THOUGH IT IS HIDDEN. This is a bug.
It becomes a problem when you have a huge scene with many paths and objects.
The paths start blocking access to the other objects in the scene.
OS: Windows 10
  •  2
  •  2416
Bug
Submitted byjasonjbrown Dec 20, 2016
COMMENTS (2)
Dreamcube017 Dec 24, 2016
I just saw the original post and the lock is literally right next to the hide option.
Maybe when they say it's solved, that means it's in the next version or on the roadmap.
