Votes
0
Product:
iClone 8
Version:
8.52
Status:
Assigned
Issue 11829
Morph targets do not transfer properly from iClone to Unreal
There seems to be a bug in the latest AUTO SETUP FOR UNREAL (1.37.7211.1) with the latest iClone (8.52.3605.1) , with the latest version of Unreal (5.5.3). The facial morphs (for facial expressions) make the character distort all over. I made a quick video about it, and explanation is below:
https://www.youtube.com/watch?v=PwKK6vfpPrI&ab_channel=TobyVirtualFilmer
First, in iClone (8.52.3605.1) I opened the Kevin speaking project, and went file > export > FBX. Then chose unreal, and exported.
Second, I downloaded the latest unreal auto setup from Reallusion
(Which is Version 1.37.7211.1)
Then I made a new 5.5.3 UE project, quit unreal, copy and pasted the “content” and “plugins” folders from the auto setup directory into my unreal project, then reopened unreal. I made sure to check that the logo for auto setup was in the top ribbon in unreal, and it was.
Third, I imported the FBX I exported from iClone. It came up with the auto setup popup, and I chose hq shader. Then in the next popup I chose all the specific settings that the instructions page says to.
Installing Character Creator & iClone Auto-setup for Unreal 4.
It imported - took a few minutes.
I opened the SKELETAL MESH and tried to adjust the MORPH TARGETS, and they were all messed up.
Then I opened the animation sequence that came across from iClone, and again, it was all messed up.
OS: Windows 10
  •  3
  •  81
Submitted bymrtobycook Feb 21, 2025
COMMENTS (3)
Feedback Tracker Admin Mar 20, 2025
HI mrtobycook ,
It has been found that this is an issue with Unreal 5.5 itself when importing. Please refer to the following WorkAround method.
- https://courses.reallusion.com/home/iclone/pipelines/unreal?keyword=5.5&sort=3&v=updated-workflow-for-unreal-engine-5-5-auto-setup-%7C-character-creator-4-tutorial
JoePan
Reallusion
Farouce Mar 18, 2025
Having the same issues, morph target / blendshapes are not working correctly when using Live link  Iclone 8 / UE5.5.3
Feedback Tracker Admin Feb 24, 2025
Hi mrtobycook,
Thanks for your Feedback,
The issue can be successfully reproduced and has been reported.
JoePan
Reallusion
