Votes
0
Product:
iClone 7
Version:
7.61
Status:
Released in 1.21
Issue 6249
Morph Animator changes do not update in the Iray Preview window
Steps to duplicate this issues:
1) Add a prop with "Morphs" to your scene
2) Do an Iray PREVIEW
3) Move the prop, or change its color, etc., and the Preview image will update
4) Open the "Morph Animator" panel... CHANGE A MORPH VALUE... the Iray Preview window will not update
Additionally:
5) After changing a morph, do a change (such as moving a prop) that will cause the Preview window to re-render
6) The morphed mesh will still be unchanged
WORKAROUND:
To see the newly morphed mesh, you need to CLOSE AND RE-OPEN the Iray Preview window.
DESIRED RESULT:
Changing Morph target values should cause the Iray Preview to refresh and update
P.S.
This was first noticed in iClone 7.6, and then duplicated again in 7.61.
OS: Windows 7
  •  5
  •  1448
Submitted byjustaviking Sep 10, 2019
COMMENTS (5)
Ascensi May 27, 2020
Hi Guys, if you don't automatically see an update, manually press the preview button on the Iray Tab.  This issue is not exclusive to morphs, sometimes it just doesn't detect changes and must be forced to preview.
Feedback Tracker Admin May 28, 2020
Hi Ascensi,
In order to keep the performance, the Morph Animator function can be better adjusted. Therefore, during the adjustment process, Iray automatic update will be suspended first. In the past, the data could not be updated correctly, so even if you leave the Morph Animator panel, Iray can not be updated, and subsequent adjustments will also produce erroneous results. If you want to view the correct results, you must restart the Iray preview panel. Now, you do not need to restart the Iray preview panel, just quit Morph Animator to get the correct result update.
Soya
Reallusion
Feedback Tracker Admin Sep 24, 2019
Hi justaviking,
Thank you for the detailed steps. We have repeated and reported to RD. Thank you.
Soya
Reallusion
eli@goget Sep 10, 2019
hello folks!...i am running iclone 7.61 and its not showing my project in the viewport but it does show through iray renderer...it seems its not using the GPU...my pc has an NVIDIA RTX 2080 (8 GB), INTEL CORE I7-9700KF CPU with 64gb of RAM...Please kindly assist with this problem.thank you
In this Forum thread - https://forum.reallusion.com/FindPost422447.aspx - Sonic7 stated that MOVING the morphed item DID cause the morphed item to update in the Preview window.
I did not get the same result.  In my case, my MORPHED ITEM was a SUB-PROP, and I was moving the parent.
Other than that, we both got the same result of changing the morph did not cause the Preview window to update.
Please remember the main point, which is the Preview window should update when you adjust a morph slider.
sonic7 Sep 10, 2019
I have been able to confirm that the Morph Animator changes do not update in the Iray Preview window.
