Issue 11311
Max Texture Rendering Output Both iClone and CC4
Since the last update when I export a file Render Both in CC4 and iClone if I use the Max texture size output the resulting Image or Move Regardless of the format of the file chosen it comes out without the texture see attached images. Now I'm not attaching the movie because it's way too large but the resulting movie from the instant you click render, it starts rendering frames that looks like the error images that I'm attaching. Now if I Don't check the box in the render settings that says Max texture size it comes out correctly textured. I used to be able to choose this before the last update this just started both in iclone and CC4. Once the process has removed the texturing in the program the only way I can restore the textures is to relaunch the program. Can't find a way to refresh it without restarting the program.
Submitted byLairdPaul
May 17, 2024
