Material names with blank spaces go missing when read into Maya via the OBJ format. Blank spaces in the naming structure are now replaced with underscores
STEPS TO REPRODUCE 1. Launch 3DXchange 6 2. Import a iProp file (e.g. Cat) to program 3. Pick “cat” mesh on Scene Tree 4. Go to Modify > Material, input “cat 01” to Select Material, then press Enter on keyboard 5. Export it to an OBJ file 6. Launch Maya and import the exported OBJ file
ACTUAL RESULT Fail to read the material
EXPECTED RESULT The exported material can be read
OS: Windows 10
0
2348
Submitted byFeedback Tracker Admin
COMMENTS (0)
You are going to edit a submitted issue. This issue will be changed to private draft mode until you click submit again. Are you sure?
