Issue 24
Material info won't be identified completely if load UDK OBJ files with unicode to 3DXchange 6
STEPS TO REPRODUCE
1. Launch 3DXchange 6
2. Load a UDK OBJ file using unicode, check Material tab
ACTUAL RESULT
Only two kinds of material can be found by 3DXchange
EXPECTED RESULT
All of three kinds of material can be found by 3DXchange
Submitted byFeedback Tracker Admin
You are going to edit a submitted issue. This issue will be changed to private draft mode until you click submit again. Are you sure?
Do you want to delete this issue?
