Issue 3650
Masking body parts in Motion Puppet no longer works properly in 7.1
In previous versions (7.02 and below) if you applied, say, a walking motion to a character then masked out the lower body and applied a different motion over the same frames to the upper body, the walking animation would remain and the new motion would affect only the upper body.
In 7.1, using the same procedure, the lower body walking animation will freeze at the first frame, while the upper body will animate as expected.
This problem also applies to the Mocap plugin.
I had installed the Curve Editor Trial, so I uninstalled it and retested, and got the same result.
Thanks.
Submitted byemergencySquirrel
Nov 18, 2017
