Make sub-prop for an OBJ file in 3DXchange 6, and then bring into iClone 6, failed to use physics for the new object
STEPS TO REPRODUCE 1. Make sub-prop for an OBJ file in 3DXchange 6 2. Export prop 3. Load the prop to iClone 6, switch to PhysX and check Activate Physics
ACTUAL RESULT Failed to use physics for the new object
EXPECTED RESULT The sub-objects can be set to soft cloth
