Issue 5333
Iray Tonemapper Template - Need an easy way to reset to default/none
On the Tonemapper Template menu, if you pick one, there is no obvious way to return it to the original default setting.
I had to open a new project to discover that the default template is "dscs315," which appears a long way down the list, and a user would never guess that was the original template.
REQUEST:
1) Name the default template to be "None" (or "Default," but "None" is more clear)
2) That should be the very FIRST template in the list. Since the list is currently in order of a simple ASCII sort, prefix "None" with a Space or Hyphen if you need to in order to make it be the first one on the list.
Submitted byjustaviking
Oct 29, 2018
