Hi onlinebuddyxxl, In order for us to fix the issue, we need to be able to reproduce it. For this we need a precise description of what you did so that we can clearly follow your actions and recreate the same situation. Here is an example to help you get started: STEPS TO REPRODUCE 1. Click the product’s icon on the Desktop or Start Menu 2. Wait for it to launch 3. Navigate to Content Manage > Project 4. Select a random project and click on “Apply” 5. See whether that project can successfully be applied ACTUAL RESULTS The project can’t be applied EXPECTED RESULTS The project can be applied
If you have a skydome on at the same time as the auto sky plugin the dome will be the only thing indigo renders, so try turning off the normal skydome if you have one. hope this helps
