Votes
Product:
iClone 7
Version:
7.21
Status:
Active
Issue 3927
Include in the manual: Look At feature, the first application, switching between objects, disconnecting from objects; control the transition time in all three cases.
Hello!
This is not the first time that the topic The Look At feature has been raised on the forum:
https://forum.reallusion.com/362606/Character-look-at-How-it-works-Where-is-the-Transition-Areas
https://forum.reallusion.com/369881/is-there-a-look-at-issue-with-v72-
Please include the following in the manual:
First "Look at" application and transition time:
1. Right-click the mouse a little earlier choose Release, get a triangle - this is to regulate entry into the "Look at".
2. In the subsequent frames, set "Look at" the object you want.
Switch to another object (if there is one, or see the Finish immediately)
For a few frames before switching, make "Look at" the previous object (simply copy and paste "Look at"). We get two triangles to regulate the transition section!
Finish the "Look at":
1. We release from "Look at" a place where the influence should end (and in fact the actor has long been looking the other way).
2. Go back a few frames back, copy and paste "Look at". We get two triangles to regulate the transition section!
And: In the timeline right click a look-at keyframe open transition curve presets to have custom motion between keyframes.
https://youtu.be/eDaKJagsJvg
OS: Windows 10
  •  0
  •  1065
Submitted bydogged2003 May 28, 2018
COMMENTS (0)
