thats fine soya ..i just didnt understand the initial response..said was a video attached i didnt see anything and talking about render size i guess that will indicate screen resolution but that was more confusing than ask screen res i should have included in my intial report...anyways no big deal. I will try and locate the exact project file and see if it still manifest..thanks
calvin i did some more testing so far i cannot replicate..im trying to find the exact project file and see if it shows up anyways if it comes up again i will make a video.
Hi hobbyuser3d, Thank you very much for the keyword "3840x2160". We will test a 4K monitor to see if the aspect ratio affects UI operation. We will let you know when we can reproduce this issue However, we are very sorry. We are now celebrating Chinese New Year. We will start work on Monday, February 7th. So it will be a bit slow to reply to you. Soya Reallusion
set your monitor resolution to 3840x2160 as mine follow my listed steps..i have no time to make you videos.. this is a gui issue nothing to do with render
hello Calvin this has nothing to do with rendering anything or the render image settings...re read the issue i wont waste my time if you cant even understand the bug report. If you are talking about render anything shows you do not know what im talking about. I suggest you re-read the bug report carefully. And return with a new question.
