Votes
0
Product:
iClone 7
Version:
7.3
Status:
Released in 7.3.2205.1
Issue 5166
Iclone 7.3 rendering image sequences at wrong frame rate/speed
Iclone 7.3 is rendering videos fine but Image sequence rendering is broken.
When attempting to output at 30 FPS (for example) the resulting images play too slow once in video, perhaps at half speed.
Additionally the rendered image files have the wrong frame numbers.
OS: Windows 7
  •  5
  •  3307
Bug
Submitted byDr. Nemesis Sep 28, 2018
COMMENTS (5)
mrbeluci Oct 1, 2018
It is also taking a longer time to render than the previous version.
animagic Sep 30, 2018
The issue seems to be that the image sequence is always rendered at the project frame rate of 60 fps. The render frame rate used to be and should be adjusted according to what the user has selected. So a project of 240 frames (4 seconds), should render 96 frames @ 24 fps, 100 frames @ 25 fps, and 120 frames @ 30 fps.
TonyDPrime Sep 30, 2018
RL -
Ran sample project for 400 frames, rendered image sequence @30 FPS.
So I am expecting 200 frames, like in 7.22.
What happens is it renders at 60 FPS, despite me having selected 30 FPS.
It renders all frames, for a total of 400 rendered images, and numbers them as if it were being run at 60 FPS, 1-400.
While it is doing this, it shows the countdown from 0-100%, and the 100% shows at frame 200, but then you see it proceeds to render frames 201-400, all while still showing 100%.
So, it conveys the info in a disjointed fashion, where it still 'thinks' it is rendering at 60 FPS, while simultaneously thinking it is complete after 200 frames.
Perhaps related to change in code involving the new discarding of simulation frames, now part of the realtime render function.
toystorylab Sep 29, 2018
It's silly i have to vote to fix a very important function that is broken ;-(
Kelleytoons Sep 28, 2018
Yep -- also somewhat related is the (very) odd way iClone reports frames rendered (it shows completion LONG before it's ever completed).
