Votes
0
Product:
Version:
1.0
Status:
Not Reproducible
Issue 11824
I cannot use IK(inverse kinematics) and FK(forward kinematics) at the same time without resetting the pose
I used Actor Core Accurig to give my model a rig to control. once i was done, I downloaded auto setup for blender to riggify the model once ported from Accurig. first, the models rest pose was odd, i had to clear all transformations for it to have a normal t pose. second, when i riggified it, the model kept returning to a odd rest position where i had to clear transformation again then set as the default by making a key frame for it. finally, i started to pose the model with IK controls and notice parts of the rig didn't move, then when i swapped to FK the model reset back to the rest pose. I am not able to use IK and FK at the same time, each time i swap all posing gets erase. i tried clearing all transformation but nothing works. thank you for the help and time.
OS: Windows 11
  •  2
  •  84
Submitted byjetix109 Feb 20, 2025
COMMENTS (2)
jetix109 Feb 28, 2025
this is the model fbx
Feedback Tracker Admin Feb 26, 2025
Thank you for your feedback.
Please provide your FBX or OBJ file to help us identify the problem.
You can attach the file in your next comment. If the file size is larger than 10MB, you can use cloud services such as Google Drive, Dropbox or OneDrive to make the files available to us and put the link in your comment. you can use private comment if you want to keep it private.
Allen
Reallusion
