Issue 8422
I can not get output. Unable to obtain elements and rgb channels.
In the process of creating and rendering characters, it was confirmed that you can hang the batch render with the iray's render scene button.
Set it to the Export settings window with the render scene button and press the render button with preview resolution,
The mi files should be extracted and output in the folder, but the mi file will be saved, but the output image will not be displayed.
Only depth and normal channels come out.
I'll reinstall the program
If you convert to iclone and try iray again,
The results are the same.
Is there a problem with my license?
There is no problem saving one sheet at a time in the preview window.
Submitted byblack_080054
Apr 22, 2022
