Votes
0
Product:
Character Creator 4
Version:
4.32
Status:
Assigned
Issue 10868
How to pull skin to complete skull
I am using the Keen tool to generate Skull and bring it to Character Creator v4.32. The Skull is all black and as I understand I have to pull the skin of the character. Maybe that question does not make sense. Would you please be kind enough to guide me on how to fix it?
OS: Windows 11
  •  2
  •  269
Submitted byagha.khan_940305 Oct 30, 2023
COMMENTS (2)
agha.khan_940305 Nov 9, 2023
The answer you provided is not correct. It used to work, as you may see in this picture. After updating your software, it stops working. We are using your software to make our life easier. Kindly explain why it worked before and why it stopped working now.
In a real sense, I should use what you are suggesting in the video. Building a model from a picture is a legacy procedure.  When I clicked the model tab, your software prompted me to select mode, but how? Your video brings up file explorer for loading the model, but how. I do not see an instruction to load the model.
Feedback Tracker Admin Nov 10, 2023
Hi,
We're terribly sorry. Could you provide us with your oringal model to clarify ?
It can happen in several situations for your case:
1. The original model and textures are fine, but Headshot didn’t bake the textures well.
2. The textures in these areas of the original model were originally black, so this is how it came out after baking.
3. Your original texture is complete, but the UV is wrong, causing a bake error during Headshot bake.
The previous replies were mainly to exclude these problems, so we posted this tutorial.
Soya
Reallusion
Feedback Tracker Admin Oct 31, 2023
Hi,
This video for your reference:
https://youtu.be/k4tSjMABH9I?si=XhdskdHd7Cn7tF-p&t=183
The video content mainly uses the skin mask function that comes with Headshot 2 to fill in the missing textures. If the missing area is still not covered, then you can export the Diffuse texture to other image editing software for repair.
Soya
Reallusion
