Issue 11473
GoZ Plus not working
When I send a model from ZBrush to CC4 I get the error "Because this data transfer from ZBrush is not performed using the CC GoZ Plus plugin, Diffuse and Normal maps will not be updated. Would you like to proceed?"
Using ZBrush 2022.0.8
The box "Enable GoZ Plus" is checked on the GoZ Settings dialoge box.
As far as I can tell, I did install the Plus plug-in. Is there a way to re-install it or confirm it's installed properly?
A new issue has cropped up. Now I can't send anything to ZBrush, but I can send models to CC4.
When I click the GoZ button to send the models to ZBrush, I get the following error:
"The GoZ has been interrupted due to data processing in ZBrush. Please wait for the process to finish, or click the "Restart CC GoZ Plus" button in the ZBrush CC GoZ Plus plugin if this message persists, then try again."
I was able to send models to ZBrush yesterday and not today. Nothing has changed in my system, not even any updates.
I can't find this button mentioned in either ZBrush or CC4.
I've reinstalled the GoZ plugin on the ZBrush side multiple times.
Restarting doesn't do anything.
Reinitializing ZBrush doesn't do anything.
I get the same error even when ZBrush isn't running, so that seems to indicate CC4 isn't actually communicating with ZBrush when exporting.
Submitted bybloodylemming
Aug 17, 2024
