Failed to Create / Surface, Particle, Billboard contents when the Resource pack is not installed.
STEPS TO REPRODUCE 1. Install iClone 6 2. Make sure that the Resource pack is not installed 3. Launch iClone 6 4. Go to Menu > Create > Particle > Rain
ACTUAL RESULT Fail to apply this content
EXPECTED RESULT All of Surface, Particle, Billboard contents can be applyed correctly under the condition that the Resource pack is not installed
OS: Windows 10
0
2429
Submitted byFeedback Tracker Admin
COMMENTS (0)
You are going to edit a submitted issue. This issue will be changed to private draft mode until you click submit again. Are you sure?
