Issue 3604
FaceAnimProfile load problem
I'm having a problem in 3DXchange when trying to load a FaceAnimProfile onto a Daz Genesis 3 character model.
So far I have built the model in Daz and applied the "DAZ Genesis Extension" files. Then I exported the model to iClone through 3DXChange. When I had the model in iClone I noticed the Viseme mouth shapes were a bit off (eg. the lips didn't touch for the BMP sound). So I went back into 3DXChange and refined the mouth shapes in the expression editor. Then I saved the FaceAnimProfile because I have multiple scenes the character will be used in and I have to import the model multiple times. So I opened the model again (the same exact model as the model I used to set up the FaceAnimProfile) and tried to load the FaceAnimProfile and 3DXchange gave me the error message.
I also tried this with an other character model to see if the problem was isolated to the first character model and 3DXchange produced the same error for that new character model.
Any help would be appreciated. Thank you.
Submitted bydaytimestudio
Oct 18, 2017
