Issue 5382
Enable Quality control in Iray
While Quality control may not be much useful for stills rendering, it might be quite valuable for rendering animations. Preset samples count for the entire export batch maybe too much for rendering specific frames in the animation sequence. Quality control might help to arbitrary lower samples rate for specific frames by using calculated pixel convergence.
As of now, Batch Renderer has quality control disabled (even if this option is explicitly applied to the "Scene Options" in the .mi file).
I had an opportunity to test it a bit in DAZ however, with the default Quality control settings.
In DAZ I did render 30 frames of Bluray project with quality set to the default value of 1. It finished rendering in: 9:20
Then I turned the Quality OFF and rendered the same 30 frames: 12.40
While I was rendering with Q=1, it stopped the frame render at approx 75-80% of the default 500 samples and then moved to the next frame.
Here is a 6 seconds animation (I set 10 FPS). First 3 seconds is with Quality control ON and the next 3 seconds is without it. I think it handled sampling fairly well.
https://youtu.be/HXWy29jqqzMI would also love to see the Quality control available in the Batch Renderer UI so that user can adjust settings on the fly after exporting animations.
Submitted by4u2ges
Nov 10, 2018
