Votes
0
Product:
iClone 6
Version:
6.42
Status:
Released in 7.0
Issue 354
DOF doesn't work when clicking “Super Sampling” on Render panel
STEPS TO REPRODUCE
1. Launch iClone 6
2. Apply embed project Default
3. Navigate to Toolbar > Camera & Object Switch (U)
4. Go to Modify > Depth of Field, check the the box for "Activate", click "Pick Target" button and pick a random object (e.g. Crystal Ball), then change the value of "Focus Range" to 200
5. Open Render panel, check the box for “Super Sampling”, then click to export
ACTUAL RESULT
The selected object is not blurring and everything in the scene is in focus
EXPECTED RESULT
The Render result is the same as Preview result
OS: Windows 10
  •  3
  •  2842
Bug
Submitted byFeedback Tracker Admin Apr 28, 2016
COMMENTS (3)
animagic Sep 13, 2016
The link parser doesn't work correctly. The link should be: http://www.reallusion.com/FeedBackTracker/Issue/Depth-of-Field-not-working
Although the DOF problem is marked as "Released" in 6.50 in the related issue 327 (http://www.reallusion.com/FeedBackTracker/Issue/Depth-of-Field-not-working), it is actually now not working at all, regardless whether Super Sampling is on or off.
justaviking Apr 28, 2016
Good write-up.
This DOF issue is listed as "ACTIVE" in this entry:  http://www.reallusion.com/FeedBackTracker/Issue/Depth-of-Field-not-working
If that means what I think it means, then it's great news.
I wonder why this is marked as "Hold" instead of "Duplicate."  The details vary slightly, but it's definitely the same topic.  Oh well, I hope the fix is good and thorough.
